96 Mark VIII that seems to not want to start
Winston Salem
some days my mark starts right up, but hear lately i have had days where she turns over but acts like theres no fuel. After a few attemps she comes to life. Im supecting a Crank Postion sensor or a fuel pump related issue like a failing relay, or is there a one way valve that prevents fuel from reuring to the tank?
any thoughts?
any thoughts?
Review the archives.
1) 1st check the wires going into the crank sensor.
2) If wires OK, then replace crank sensor.
3) Check wires going into cam sensor.
4) Replace cam sensor if wires OK.
It will be one of those 4 things, most assuredly.
thanks ill do that, i check all data to find these senders
Thanks for all the help, got tied up out of town for work. Shes fixed and it was the Crank sensor. Not a bad fix either other than the whole moving the A/C compressor thing. Heres a tip ford dont tell you, unplug the sensor first, then lower the A/C Comp. It will save you a lot of trouble.
Thanks again for all the offers.
Staff online
