BAD97LSC
dont ask, i need the money, i know i know i was supposed to give it to my wife but she's gonna hold onto her lincoln for awhile. its for sale, 97 catera, new engine oil cooler direct from germany, heavy duty never worry again, all new gaskets and hardware, new water pump, new timing belt, new radiator, new hoses, runs like a dream. shifts great this car gets up and scoots, turn off the traction control and believe it or not you'll blow it sideways. 4 wheel independent susp with a posi. dual climate control, 6 speaker stereo with controls on the steering wheel, 12 disc aftermarket changer in the trunk, 2 matching spare wheels in the trunk, one has a fullsize spare on it the other is just a rim. ac is cold, heat is hot, has homelink on the rear view mirror, power everything loaded up all leather car is light gold with brown and cream interior. 76k original miles. i'll even give you the cell phone that was in it!
now the items it needs still. glove box latch is broken but you can still open it, i have the handle but i dont think it will go back in, needs to be replaced, needs front windshield, cracked across the top but doesnt leak, right rear window needs a power motor, front lower control arms need new inner bushings, they are worn and clunk on bumps, no biggy, may need a brake light switch, brake lights come on 9 out of 10 times, its intermitant, and also the coolant cap on the pressure tank needs a new rubber gasket, the one that was on there swelled from the leak it had, i can get this and put it on if you want, all its causing for a problem is when the car is hot and the coolant comes into the tank when you shut it off, a little coolant seaps out from under the cap since there is no seal. again no biggy. the car runs and drives awesome i actually like how it drives but i need money more than i need 2 cars right now. title in hand, come drive it home $2,100 and its yours. you can put it on the road as is right now. its gotta go.
email with questions jamies98lsc@aol.com
