97 Lincoln Continental No Horn
Linc97
USA
Help! The horn is not working on this car and I cant find a solution for it. Any help is welcomed. .
Welcome To LVC. Did you look at your fuses. It should be under your hood and the number of the fuse is 17 but make sure to look at YOUR mannual because mine is a 95 and yours a 97.
yea i had this same problem ones
um
you probly just need to change the fuse
but make shure you look at a 97 manual couse the fuse might be a difrent number man
you actually might want to check to make sure that the connections at the horn itself are properly connected. Sometimes something can come loose and it would obviously cause it not to work.
