97 lincoln lopes when at a light
garyg
dunedin
i have a 97 continental and here is the problem im having when im driving i cant feel anything it drives fine no hesitation can be felt at all but when i come to a stop the engine kinda jerks a bit or maybe bumps is the word that would describe what it does i have read somewhere it is prolly a vaccum leak in the brake booster line or even the booster itself cause it only does this when at a stop any ideas.
with some more info we can help you better..
how many miles on engine, how long since last plug change, ect...
one thing to do, is get the codes pulled... even without a check engine light, there may be codes... and if there are any, they can help us point you the right way.
While I don't have this vintage lincoln, or a ton of knowledge about them, I understand they have some common problems that can cause what your describing... thats why we need a little more info.
fixed
ok everyone i did the sea foam thing and the problem disappeared
cancel that it came back after a day i think it possibly could be a vaccum leak at the pvc or brake booster line will check to see btw it is a 97 with 113k miles
Staff online
