97 Lincoln Mark VIII LSC Clean/Reliable
lax2173
Long Island
Vehicle Highlights
Mileage: 148,000
Engine: 4,605 cc 4.6 liters 8 V 90° front longitudinal engine with 90.2 mm bore, 90 mm stroke, 9.9 compression ratio, light alloy block, light alloy head, double overhead cam, automatic valve adjustment and four valves per cylinder
Transmission: Automatic
Drivetrain: RWD
Power: 290 HP @ 5,750 rpm; 290 ft lb @ 4,500 rpm
Completely re-done sound system
alpine type-4 speakers x2 in back
JVC door speakers in doors
stock JBL tweeters
MTX Jackhammer amp
MTX Thunder Squares -http://www.mtx.com/caraudio/products/subwoofers/IndexTSquare.cfm
* ABS Brakes
* All Speed Traction Control
* Spring Suspension Conversion Completed
* LSC package
* Cruise control
* Heated perforated driver's and passenger's seats with separate controls for the seat backs and bottoms
* Driver's and Passenger's seat Auto glide system. Tilt the seat back forward and the seat power glides forward
* 6 way memory seats for two drivers (sets seat position, steering wheel, radio, external mirrors)
* Aftermarket HID headlights
* Puddle lamps built into the rear view mirrors
* LED directional signals built into the rear view mirrors
* ABS four wheel disc brakes
* Keyless entry system with programmable personal combination
* Programmable tilt down back up mirrors
* On board diagnostic system
* Mirrors: all auto dimming, heated outside mirrors, auto dip in reverse
* Headlights: auto on/off
* Power Windows
* Power Door Locks
* Steering: variable ratio with two driver memory tilt/telescope column
* And of course all the goodies such as cruise control, climate control, leather, heated seats, etc.
$4,000 OBO
located in Westbury Long Island
Vehicle Highlights
Drivetrain: RWD
So it has a Mark VIII drivetrain in it? lol
150k
Air ride is gone.
Don't think you will see 4k around here.
Try your local craigslist.
How about some real facts?
Is it stock HID still? If yes do they still work?
Rear neon work?
Does it have heat? "blend door work"
When if ever has the front end been gone through?
"upper control arms, lowers ball joints, strut rod bushings".
Any j mod?
Trans been gone through yet?
150k
Air ride is gone.
Rear neon work?
Any j mod?
ok my fault i did throw it on Craigslist and it is obo
it is aftermarket hid change last fall and work great
rear neon does not work
heat works and blend door actuator was replaced 2 years ago
upper and lower control arm and bushing and stablizers have bin replaced all within the year
new coil packs
oil change every 3k
and j mods are?
trans and rear are stock and have given me no problems.
car has giving me no problems.
will take pics of system this weekend and interior is the only down fall due to normal wear on leather seats
Good luck on your sale.
How come your selling?
Looks clean for a NY car.
thanks and again thanks for making it clear on what to point out
looking for something new dads got new toys and so does my brother so i want a new toy
runs great i call it the silver bullet
i mean regular highway niks but thats it
i wanna respray the wiper arms soon and just detail the motor as usual it is my daily so i take care of it
If it was me I would keep it.
Put 4.10s in the rear...or 4.30s, upgrade the trans and drive shaft, get a sct and a tune, new converter with a higher stall, maybe spray it. "nitrous oxide"
You would have your new toy. :)
Is it rust free?
Any underside pics?
It would be your best selling point if it is, your in the rust belt.
Its about a $100 bucks to fix the neon.
It would help selling it.
http://markviii.org/~glitch/inverter.html
only rust on top of my head is inside engine compartment on passenger side wheel well there are few bubbles
great color...hold out for your 4K...the guys around here are a bunch of cheepos who want everything for nothing...my opinion of course.
Buy it ratdog, then you can enjoy a gen2, you think its worth 4k. :D
actually the members here know what its worth.
Its what I told him in post #5
Far from being cheap, just know the cars value that's all.
150k
