pantera101188
the car has 350k on the clock although the cluster states 150 the cluster was switched.the motor and trans are shot im sure the motor doesn't have much left to it all thought it wasn't making noise or running funny and the trans is shot wont shift out of second.the tires were put on in January the intake was done some time in febuary the front end was done with the tires there are a few scratches but nothing major.the drivers seat more then likely isn't usable but the rear seat is near mint.the hood also has the high millage ford peel.and there's some missing off the trunk. other then that no dents also needs the driver side front abs sensor.i just did the one in the passenger rear and then the one on the drivers side went out after replaced that.i put back in the stock radio but i found out the person who installed the radio for me did hack the plastic were the radio goes so that's no good eater unless maybe using for a double din radio install.im not good at wiring so i had some one who i thought knew what they were doing install it for me.any questions please message me i can also message pictures back as well just not sure how to put them up on this page
