97 mark 8 gaskit ????
jakefyock88
Spring Hill
ok so i have a bad vacumn leak its sounded like it was coming from the throttle body or the intake gaskits. i changed the throttle boddy gaskit and bought the upper and lower plenum gaskits wtch were two long strip lookin gaskits, i dont need them. but when i removed the intake i noticed i needed the two oval gaskets that are about 4" long please respond with the part name or part number thanks
Well, not to be a deutsche or anything but you're probably not going to get a lot of responses because, frankly you sound like you just came out of the second grade. I can dismiss a few typos and I don't claim to be the spelling police, but you make yourself look like you have a negative iq when you you come on asking for help with part numbers on 'gaskits', and make it appear like you wrote your first post drunk. I suggest the edit button, and also welcome to LVC. Haha I beat frogman to it.
What exactly is a "deutsche"? Were you guys in the same spelling class? ;)
As for the gasket talk to Max at 5 Star Ford (link on the right sidebar) and he should be able to set you up with them...
All 8 of my brain cells are seizing after trying to read that.t..tt.......tt............t
