zal
I have a 99 Continental that mechanically is running fine. But, The power windows, door locks and mirrors do not work properly. Also, which may or may not be related, the display sometimes displays Low Washer Fluid, despite the fact the reservoir is fill.
The power windows do not operate properly from any of the switches. When I press the button in the down position, I hear a click and the window sometimes moves down a very small amount and stops. The same behavior occurs when I press the up button.
The power door locks do not function from any door lock/unlock buttons.
The power windows do not appear to move at all when using the controls.
I opened up the drivers side door and discovered a module that the buttons are a part of that also connects to the power lock and power window controls. I thought that this must be the part that went bad, so I ordered a working used module and replaced it. Unfortunately, the new obtained used module did not fix or improve the problem.
What else should I check? Any assistance is greatly appreciated!
