Adam_Dawg78
Over the winter I posted problems about having no heat. I replaced my temp gauge, degas bottle and finally DCCV and finally fixed the heat issue. Well now the south is heating up and we went to turn the A/C on but only got HOT air. Ive checked fused, done the front dash display test and can't find anything wrong.
My guess is it might need a Freon recharge. I wanted to see if anyone knew how to test the pressure. Ive searched and searched and found all kinds of post but people more than less just discourage it. I have the tools and just want to check and see if it is actually just the Freon and not something more.
Car
2002 LS V6
I mention the 2002 because ive read the lower port is behind the front driver side tire, but another thread I read said on the 2002 models they moved it to he accumulator or somewhere like that.
So if you can help me with where to locate both ports, what pressure to look for and if low advice on recharging.
thank you
Car
2002 LS V6
thank you
