A couple of questions...
Vivid LS
Worcester
Is there a way to have the angel eyes turn on when the car turns on? Do the bulbs have a short life span if they are on all the time? Could you wire the power to the cigarette lighter or something like that, the way it is now they work with the parking lights.
Also does anyone know the size of the bulb that goes in the front bumper turn signals.
The headlight part is 3157 how about the bottom light?
Thanks
The side marker bulb size is 168. As for the angel eyes, you can run the all day long if you want. You shouldn't have a problem with the ring going out. The weakest link in the angel eye system is the inverter. Those typically go bad after a certain time frame and you replace those like you would a light bulb.
You can wire the angel eyes to anything you want.
