MRB73
I have a 92 LSC S/E and the check ABS light is on.After checking the codes I found that the right rear sensor is bad.I found a new sensor and tried to replace the old one but I can't figure out how to remove the old one from the car.I took off the caliper,rotor and dust shield.Took the one screw out that holds the sensor on but I can't get it to come off.Any ideas on maybe what I am doing wrong?
