ABS Pump motor leak?
Well, I found some brake fluid dripping from my front driver side framerail, obviously a leak somewhere. Traced it to the ABS pump motor (had to get under it with a mirror to actually spot it. Appears to be coming from the connection between the motor & the pump itself.:slam  I see some blue silicone (or is it a demo-ed o-ring) squeezing out between the motor & the pump housing. Can you actually separate these 2 parts or does the motor and the pump have to be replaced as a unit? What might be the actual source of the leak? Internal pump seals? The ford manual exploded diagram does not show these as 2 separate pieces. Please help!:bash:
