ABS Removal
91lsc5spd
u.s.a
Hey Guys just wondering if anyone knows what is all involved in eliminating the abs on my 91 lsc. Also What Brake booster and master cylinder i would need to use? Thanks
im very much interested in this subject also, if its been done before please explain, im pretty sure that a pump from a fox t-bird or cougar was used.
No, you use a master cylinder from an SVO Mustang. It's been talked to death on fordvschevy.com, so do a quick search over there and you'll have more information than you'll know what to do with. ;)
is the svo pump a direct bolt on, or do you have to modify inorder to make it work.
