Wow, I didn't say anything like that at all.
There's no such thing as a short in a fuse. A fuse is itself a "short" until it is blown, then it is an "open."
If fuse F1 is blown it will be because:
1. There is a short in the DCCV - fairly common.
or
2. There is a short in the AC clutch - uncommon, but it happens.
or
3. There is a short in the wiring - fairly rare.
If F1 is blown, it would explain your symptoms. If F1 is blown, the climate control goes to full heat because the DCCV valves remain fully open. If F1 is blown, the compressor clutch will never engage, so if your clutch air gap is too small, it will make noise all the time.
If F1 is blown and you replace it, you may be able to engage your compressor clutch and find out if the clutch air gap adjustment is your problem or not. (If it's just the air gap, then the noise should stop when the AC compressor engages. This assumes that you have enough refrigerant for the PCM to allow the clutch to be engaged.)
So, in short, if the fuse is blown and you replace it, it won't solve your noise problem, but it will give us more information on what that problem is and what the minimum you could do to fix it would be.
