AC is on maximum or off. The heater is the same way - real hot or not on. How do you get the the mixer door operator and is it vacuum operated or electric?
Are you reffering to fan speed or actual temperature?
If you're getting both hot and cold I wouldn't think you're having a blend door issue, Sounds like the climate control module is bad (the part with the buttons on it)
what year is your Mark?
