AC Mix up
Check the vacumn lines that run from the blend door box to the control unit. (the blue/red/yello/white vacumn tube bundle.) Pay piticular attention to thw yellow line, it runs to a seperate location than the others.
Mike
I figured that. The yellow line came out some how. I don't know where it was connected. Where does it go? Can it be reconnected without pulling the dash back out?
There is a gold "Can" looking actuator on the drivers side of the blend door housing., you MAY be able to weasel your arm up there to connect it.
That is just what I need. Just when I figured out everything. I will give it a try tomorrow. I am totally dreading taking everything apart again.
Yes, it just slides on.
If you put everything together correctly, that hose should run through a retailer, that holds it close to the dash to keep it out of the way while you install it.
it just slides on to the fitting of the can.
Hope that helps.
Mike
Well, I couldn't snake my hand back there, so I bit the bullet and pulled the dash back once more. I gotta say, I am still just as lost. I can see the yellow vacuum line just laying there, I just can't see just where it is supposed to be connected. Some guidance here would really help.
