DavidT2169
Where is the port to hook up my recharge kit? Is it the port thats in back of the engine bay? I am pretty clueless with this, never done it beofre.
Actually I would be uneasy telling him which to fill at. If he cant tell that there is only one port a suicide kit can hook to then he really should not be doing it unsupervised.You really should consider getting some help if you are unfamiliar with this...it is easy to do more harm than good by arbitrarily adding refrigerant.
Otherwise, I am sure one of the VIII experts will chime in shortly with the exact location of the low-side valve. You can typically just trace the refrigerant lines until you find the fitting, too.
Filled mine for $10! Of course I used propane.... little cheaper.
Anyway, the kit tells you which port to use and usually only fit on one port. The kit will describe in detail where to attach. It really pretty easy since there are two lines. The larger line is low pressure and where you add.
And more explosive
And not only that, I need R12. R134a is NOT good in an R12 system - period. And its NOT more explosive. If I was in a wreck I would be more worried about fuel than a few ounces of refrigerant. Heck, for years it was used in AC systems on Japanese cars!
