Access holes
shuman
Queens, NY
Does anyone know if there is any access holes from the inside of the car to the engine bay? I don't want to have to drill a hole through the firewall if there is already a hole there. Thanks :feedback
I have been through this time and time again with my LS it is not installer friendly IE no holes in the firewall.... quick help me with this you can just unbolt the ECU and ran the wires thru there and then reinstalled the ECU or drill a hole next to it thats what i did.... good luck
There is an access hole in my LS under driver side dash. You have to take off the knee cover adn the if you look at the firewall on the top left of the brake pedal you should see a sponge like piece about 2x2 inches. You can pull that off and then there is plastic you pull off.
Staff online
