after market suspension?
Hoverracer8
Manchester
Im looking into lowering my LS but i need to get the car back to stock height as easy as possible, No bags yet so thats out!, I was thinking coil overs as i had them on my integra ls but cant find coil overs only drop springs, Do they make coil overs for the LS?? Also i hear a what almost sounds like a compressor after about 30-45 seconds from shutting my car off, Do LS's have air suspension?? I havent noticed and leveling or dropping of my car.
Thanks! Nate Hill
Thanks! Nate Hill
No air suspension on the LS. Sometimes the a/c makes that kind of noise after shutdown.
Ok thank you! It is just that it will be completly silent then a slight buzzing then nothing again, no key in ignition car locked. Just thought it was weird but thank you!
it's coil over shock. if you want adjstable - you can install a $2500 set of Leeda.
there are several aftermarket spring options to change the ride height, and three OE shock options to change the ride stiffness.
Actually, the Leda's are $400 each plus shipping from the UK. So around $1800 for a set. I'm a distributor for Leda. Leda has their US importer here in Knoxville, TN.
wow thank you! You are a great guy to know if you own a LS!! I will hopefully be ordering them then by spring!
