Looking to do an install in a 93 Mark VIII this weekend, I took a quick look under the hood and didn't see anywhere to run the 4g power wiring. Where is the amp wire ran in your Mark?
I ran mine through a grommet that is somewhere below the master cylinder. You have to get at it from inside the car. It is in the area where the parking brake connects. A tight fit but a good place to run it.
Thanks for the heads up guys! I got home after a 11 hour shift and had to get started. It was a to get the 4g and 8g wire through that hole. I was able to get all the power wire ran and should be able to finish the wiring tomorrow.
