Sifrino3
Worth $50? I don't like the little chrome. But I like the rest of it. Says any part store should have an adapter. Anyone ever have problems with aftermarket steering wheels? What adapter works? Same as Mustang. . .
Sifrino3 said:You want it?
You will need to do that, unless you want to eat it hard when you try to pull the wheel. But the wheel might not attach to the column the same as the older styles. Just check and make sure that they sell an adapter kit for the 90+ Mark, and you should be OK.Sifrino3 said:You think you may have to diable the air bag. Or something?
That would make sense, but don't bank on it. It's better to check on it first and make sure that there won't be any trouble, as opposed to getting half way into the column and realizing you have the wrong parts. But it shouldn't be any trouble. Just be sure to disconnect the battery for a decent amount of time before messing with the air bag, or you just might eat it! Be careful.Sifrino3 said:Mustang five ohhs have the same type with air bag. So, im sure they will have an adapter. . . I do not want to eat it. I hate air bags!
LSC SS said:no problem getting an adaptor, I got one for my grant wheel not too long ago.
does that wheel come with some kind of a horn button?? that will not come with the adaptor !!
unless you want to spend about $110 you will lose your cruise control and also you will lose your airbag !!
I'm not sure if a Grant installation kit will work with the wheel you want, as the Grant kit is designed to include the horn. They are available through Summit, though, so give them a buzz and they can set you up. I want to say the Grant number is 3149.Sifrino3 said:Whats the product number?
LSC SS said:the airbag?? what color?? how much ??
