Aftermarket stereo
lincolnx2
Ft. Campbell
I got a pioneer nav headunit and my factory tv stopped working, is it possible to make the tv work with the aftermarket head unit
Yeah it is the factory one with the DVD player, and TV that swing down from the console.
Yep here you go..The first part is to retain the headphones and then it gets into the rear to front portion.
Pin 7 red to pin 5 white
Pin 17 white to pin 15 green
Pin 8 orange to pin 6 red
Pin 18 pink to pin 16 black
on the dvd plug at the dvd player in the rear
will make the headphones work again- also if you remove the player from its plastic housing its possible to solder into the rear of the rca video input at the circuit board they are attatched to. Remove the four screws to detach the board you will see a plug coming off it that has 6 wires-5 white 1 blue, the blue is the neg video feed and the white directly above it is the positive. Tap the positive and negative of the rcas that run from the HU rear monitor output into those wires and youll have a seamless install. I also placed a rocker switch to break the positive lead into the unit to kill the video input to the rear to still be able to use the front dvd a/v inputs.
i now have audio through the truck and headphones using the rear dvd as a source and audio through the truck only when using the front dvd as the source, but both operate independantly as far as video goes, basically, i have to independant dvd players and the ability to tie the rear monitor into the front and run the same video on both. Next ill install two PAC swi units to retain both rear volume track controls and the steering wheel controls. I almost paid 400+ for this just a matter of poking and prodding since no one else knew how to help. If anyone needs better directions- email, ill do my best.
