Aftermarket Sway Bar Bushings?
neilzls
Henry
Ok I have been using this site for awhile but this is my first post. I have a 2000 V6 non-sport car with 111K and have done the upper and lower ball joint/ control arms but still have the infamous front end clunk. I also have changed the sway bar links also,that leasves the sway bar bushings.Of course Ford doesn't just sell the bushing and its just too damn hot to do the whole swaybar relacement right now. Does anyone have a part# for a universal setup like Energy Suspension for the non-sport model. I have searched threads and was only able to find the sport model referenced. I do have to say after years of getting beat up in Camaro's Corvette's and such this LS is pretty cool...of course that is with the 20's installed! If anyone can give me some short cuts on intallation of these that would be helpful,I will be doing these on a lift. Thanks for you help and I am sure you will hear alot from me in the future.
Find someone with a caliper and measure the width of the bar next to the bushings, then buy a set of that size.
Or wrap a measuring tape around the bar and note the circumference in mm. Then divide that by 3.14159 to get the approximate diameter of the bar.
