Air Compressor will not run
bfrog33
EC
Hi I am new here so any help would be great. My 94 Continental air compressor will not run. I turn on the key and after about 30 seconds the "ride control" light comes on but no compressor. I had a spare compressor and plugged it in it did not run either. One side is up and the other is down??? any ideas?
Start with the obvious things and make sure the fuse is not blown for the compressor and the switch in the trunk is in the "on" position. After that I would suggest taking a volt meter or a test light and test the plug for voltage just in case you ended up with 2 dead motors.
