heatherb33612
My air ride went out. I figured out that my problem is the dryer attached to the compressor, it was cracked and leaking air. I had it replaced, but now i have another problem. There are four hoses coming from out of the dryer and the wonderful man at allied who tried to fix the problem the first time cut these hoses and put some kid of brass fittings normally used for brake lines to re-attach the lines after replacing the leaking dryer. now i have a good dryer but the four hoses are leaking where the brass fittings where put on and also where they attach to the dryer. the car wont raise still. does anyone know how this problem can be fixed easily and inexpensively? Do I need to replace all these lines, the cost to do so? does anyone know if these brass fittings can be put on to hold all the air pressure? Also when the compressor comes on should it be blowing air into the dryer and is there a way to tell if the commpressor is blowing air, I can hear it come on but when the dryer was not atttached i didnt feel any air blowing out of it it just vibrated and made a loud buzzing noise. Someone please help!
