Air Ride Leak
blue42
Billerica
My 96 MARK VIII has a leak in the front. It will raise up all the way. Sometimes it stays up overnight and sometimes it's almost on the ground. Any ideas?
Get out a spray bottle with soapy water and see if the bags are leaking.... Depending on where you park and how extended/compressed the bags are they can expose different cracks and leak quicker or slower.
Once up turn off the air ride switch located in the trunk and you can see if it's the bags or not. With the switch off if it doesn't come down your bags are fine. If it goes down then it's the bags for sure.
If it's the bags then do as the Kid says.
