Sounds like a problem with the solenoid, I had this problem before, i had a simple way to check it. I turned off the air ride, jacked up the car and removed the solenoid from the bag to vent out all the air. I then lowered the car and turned the air ride switch back on, and started the car, I of course put the solenoid back in the bag before lowering the car. After starting the car and letting the bags inflate, they leveled themselves out, it was a plugged solenoid, some dirt or or dust maybe got in it somehow and clogged it up causing them not to vent properly. Try this first, it is a simple fix, make sure when you have the solenoid removed from the bag you check it for dirt and other nasty little things that may be plugging the solenoid. Try this and post back on the results. If this is not the problem it could be a height sensor issue.
