air ride relay
Just making sure we're talking about the correct relay first. The main "power" relay for the air ride compressor on the Mark VIII is located on the frame that holds the compressor. (black with aluminum cooling fins)http://www.americanairsuspension.com/RELAY_LOCATION.htm
.....and yes, the air suspension compressor relay IS the same as the one used on the'95- Continental, but not on the earlier Conti's.
This relay is also the exact same relay that is already on the Mark VIII for the ABS pump in case your looking for a test part. (its in the left front fender)
This guy sounds like he knows his stuff! If I ever need air suspension parts I will be calling you!
