Air spring question
TSpan
St. Louis, MO
Is it possible to have converted shocks in the front and still keep the air ride in the rear? or would that not work?
it can work but its temperamental.
you have to get the front ride height sensors set so that the car thinks the front is always full.
that way the computer will go ahead and level the rear up.
however, since the the front will never vent now, the system will fault anytime it goes to vent, so you are better off killing the system with the switch when you don't need it.
Thank you!
