Aluminum 8.8 4.10 Trak-Loc Rearend
Thomas A
Overland Park, KS
I pulled this out of my Mark VIII a couple of weeks ago to upgrade to a different rear. This rear end consists of the following:
FRPP Aluminum 8.8 Housing
Ford 28 Spline Trac-Lok
F150 "S" Spring
Motive 4.10 Gear Set
The rear end was rebuilt when the gears and TL were installed. It has 3,671 miles on it since the rebuild. They did not get it set up perfectly, so it does make some noise on deceleration. When I removed it, I found signs that the pinion seal may be leaking. I am including a new seal, Mobil 1 fluid, and new axle nuts in the deal.
Direct swap for any Mark VIII, although a drive shaft upgrade is recommended.
$450 Shipped!
