joespanova
........and yes I looked over previous threads.
I had an intermittent over heating issue years ago...........not sure what made it stop , but after a new t-stat it seemed to be OK?
Over heating as of this weekend......
Anyway , all the plastic parts are only a few years old as they've been replaced since then..........but I'm not sure as to the "list" of what you guys have suggested replacing........maybe I missed something?
The t-stat housing and pipe in the front ( cant recall exact name , like a connector of sorts ), degass bottle were replaced............even DCCV valve is new........the thing is overheating again..............and as you can imagine I'm pissed! Did I mention I'm pissed?
There is water all over engine......where the hell is it coming from because I sure as hell can't detect it?
Also , a solenoid below the filter dryer was "buzzing" after the engine was shut off and key removed from ign?
What are the most common causes...........for over heating. I just dont believe its a t-stat .
What is that solenoid for?
