Anti-Theft system questions (1997 Cont.)
jrhartman
Topless Member
Livonia
Is there anyway to disable the horn/lights feature of the Anti-theft system in a '97 Continental. Here is my problem and why I am looking to disable the horn/lights: When I use the keyless entry to lock the doors, it obviously automatically sets the Anti-theft system. Randomly the system will just set itself off. The horn will start honking and the lights come on even though nothing was done to set off the anti-theft system.
Basically I either need a fix to the random problem of the anti-theft system going off or I need to find out how to disable the horn/lights feature.
Thanks in advance.
well you could always remove the Horn and the lights fuse but then you have to plug the fuse back in at night for the light. If your anti-theft is going off, it won't let you start your car. try mannually locking your car, so it wouldn't set the anti-theft on.
There has to be a way of disabling the anti-theft system. Pulling the horn fuse is not the correct answer to my problem.
I am still flabbergasted at the lack of technical information that this site contains. With the exception of one, possibly two members that post to this section, there is almost NO correct information on here :Bang
the anti theft is integrated into the auto light module,so far i havent found a way to disable it.ill check again tonight.
john
have you tried getting a new module?i have two spares i got from ebay for 10 bucks each.
john
damn, you are just about the only one that posts in this section with any sort of useful information. I will check into the module, I had no idea is was controlled through it.
thanks
I know pulling out your fuse is not the correct way. This is from the service CD that ford has for the conti.
o System Activates Falsely
Possible Source(s):
§ Switch.
§ Circuit.
Action(s) to Take:
§ GO to «Section 18-04». PERFORM self test.RETRIEVE continuous codes for lighting control module and driver's door module. If no codes stored, GO to «Pinpoint Test A» .
