Any suggestions???
galantz28x
Saint Petersburg
I had a set of 20 inch rims on my 2000 LS, and took them off and put them on my 2005 LS. I am getting much more vibration on the 05. I also now seem to feel everything on the road. What I dont understand is now I have 2 new front tires and its still worse than it was on my 2000. I had them road force balanced when they were on the 2000. Should I try that again? ANy suggestions on what I can do to soften the ride??? Its to the point I am thinking about putting the stock rims back on.
Maybe you need a wheel alignment. my buddy was having a problem like that and the alignment cured it. if you have a lower profile tire you will feel the road more along with better grip which in fact might also induce the vibration because of the misalignment< just tossing out a few maybe's to think about
could have a bent wheel or a bad or out of balance tire. try switching the front/rears and see if it gets any better.
