eL eS said:1st spark plugs do not add HP. It can give back lost HP but to my knowledge there is no way to grant extra HP.
I did just buy some denso iridium plugs and installed them and I did notice an improvement in throttle response. But after all I have learned I could have gotten the same response from the 3 dollar motorcraft plugs. Good plugs that have not thermally degenrated will more than likely result in the same response.
I bought these more for their stated ability to disipate heat. So it is my hopes that they will help prevent the coils from soaking when they get hot becasue it causes misfire.
Ya sorry about that. I forget some times. On the 2nd Gen mark, doing plugs is the easist of ANY car that is out there. 15 minutes tops, if you really move along. DOHC (hemi) cars rock!eL eS said:I would run that route with my plugs but doing a tune up on the V6 is a big pain in the BLEEP!
LBK_LS said:You shouldn't/wouldn't get any HP gains from new spark plugs... The combustion of the air/fuel mixture is a constant (as long as the mixture stays constant).. Just like you wouldn't get a bigger bang by making a can of gas explode with a match vs. lighting it with a blowtorch.... SAME BOOM!!! I know.. dumb example, but you get the idea.
I find your ideas intriguing and would like to subscribe to your newsletter...unstoppable said:Not in an LS but I HAVE found power in using a colder than stock plug, and heres why.
Whether or not you know it the car is close to running into the knock sensors, even with good gas it happens.And when that happens the computer retards the timing as to not hurt the engine.So switching to a colder heat range plug keeps you off the knock sensor and doesnt make the computer retard the timing.
I have personally seen as much as 8-10 HP by switching from a new set of autolite 764s to a colder motorcraft plug.
In one of my dads dodge work trucks he refused to run good gas in it and it detonated like crazy even at part throttle.I switched to a colder plug and the detonation was gone.
Dutch said:I find your ideas intriguing and would like to subscribe to your newsletter...
I have always wanted to put colder plugs in my Chrysler, and they always tell me there aren't any colder ones that will fit. The factory service manual calls for Champion J12Y and I want the modern equivalent of J10Y, which was the '60s designation for the appropriate plug. Champion has replaced them both with the modern designation RJ12YC.
Do you know what is one step colder than that? It's for a 383 (Chrysler big block, not a weenie little stroked Chevy).
LBK_LS said:I am to please.... Sometimes the obvious eludes me.. but when I get it.. I put what I think in "LBK_LS" terms.. so that I understand it after I read it.
You're going to have to slow down and explain for us slow people. :NLBK_LS said:I am to please.... Sometimes the obvious eludes me.. but when I get it.. I put what I think in "LBK_LS" terms.. so that I understand it after I read it.
kleetus said:Huh?
Those are awesome, thanks!unstoppable said:I found this in a quick search.
http://www.edelbrock.com/automotive/sparkplugs.html
Looks like stock is an Autolite AR74 one step colder is AR 73 and two steps is AR72
OOH here you go.
http://www.autolite.com/tech/RacingCrossRef.pdf
kleetus said:Okay.. I'm half Polish and half German, so I'm all pissed off, but I don't know why...
I still don't understand what Lbk Ls said...
I do understand what the colder plugs do... It's kinda cheating, but I'm over it.
