MercuryLs
I have a B&M 2400 stall Converter that has less than 5000 miles on it. It's in great shape and worked great.
B&M 50402 "Holeshot 2400" torque converter.
Fits 1993-2004, Ford AODE/4R70W lockup type converter.
The "Holeshot 2400" line of torque converters from B&M will deliver a higher than stock stall speed which has advantages for vehicles with modified engines. It will enable the engine to launch the car at higher rpm where more torque is available and is a good choice for high performance street machines and street rods. The "Holeshot 2400" is also ideal for vehicles that use a plate style of nitrous system. Like all of B&M's torque converters, the "Holeshot 2400" features all new heavy duty components for increased strength and durability over stock. Stall speed ratings for "Holeshot 2400" torque converters are based on 230 ft/lbs of torque at 2,500 rpm. More torque at 2,500 rpm will give you more stall speed; less torque will give you less stall speed than the ratings.
Stall speed rating; 2,300-2,500 rpm.
I'm asking $250
I'm asking $250
