Aviator Rear Clunk/Click
Bazil
Riverside
Ok, so today my Aviator started making a click/clunk from the right rear wheel at low speeds. It does not change with making a turn, so I'm assuming it's not a diff. issue. Could it be the parking brake? The parking brake was set before I began driving so I'm just curious if a shoe could be broken or something like that. It only makes this noise at low speeds and it doesn't matter if the car is going straight or turning. Maybe a wheel bearing? Any input would be greatly appreciated. Thanks in advance.
-Bazil
since it's the same as the explorer, try checking the coil springs. it's a very common issue that they break.
Thanks for the info! The click is consistent with wheel rotation and does not change with bumps in the road. Should have mentioned that in the first post. Could this still be caused by the coil springs?
