Ok, so the last few days being off work have been alittle boring so i decided to do some fiddling around with the car.  Its hot ten months of the year here so i wanted to try out a cold air intake.  I started with my stock airbox, as it seals air tight and withstands heat very well.  When you take out the airbox it has a snorkel thing which removes easily.  I then dremeled the remaining lip flat and used some fiberglass to seal up the hole.  I cut a 3" hole towards the bottom and installed some 3" intake tubing from PepBoys down thru the bumper "hole" and underneath the car.  What i have now is a completely air tight intake routed all the way down to the wheel well.  I started it up and the suction/vaccum from the tubing is quite strong so i took an old air filter and cut out the steel mesh grid from the back.  I used two pieces that are crisscrossed to prevent junk from being sucked in, but seeing that its facing backwards i dont see debris being much of a problem.  I was planning on having it run to the front grill but it has way too much vaccum and i could see water being an issue.  I just finished about 15 minutes ago so if anyone wants some pictures let me know and i'll post.  It turned out really well.
