toby1234
Hey guys. So Ive been searching the forum and looks like a P0606 code is known to actually be a bad PCM. Here's the story leading up to this. Last saturday, car started up at 6:30am without issue. Five hours later, I get in, crank the engine, and the battery is low. I used a jumper and the car started right up. When I put it in reverse, the car went into etc fail safe mode and would not engage reverse. I then put it in drive, drove it home and parked it.
This is the second time this happens. First time happened about 6 weeks ago. That time, I simply charged the battery and all went back to normal. I tested the battery and it was good. This time however, after charging the battery, I tested it and it was bad. Tested the alternator and its good. I have a feeling something made the battery go bad prematurely. Why else would it start up fine in the cold morning but struggle 5 hours later? Also, no starting issues prior to this.
So I stuck another battery in there and when I turn the ignition to ON, the radiator fan comes on. When I try to start it, the engine cranks but does not start. Sounds like no fuel to me and from what I've read on here, thats exactly whats going on. The red anti theft light blinks fast while the engine cranks as well. So I press the unlock button on the key fob to see if its related and sure enough, the car will now start. Problem is, idle shoots up to 3k rpm and if I shift to reverse, idle drops to less than 800rpm, etc failsafe comes on, and the engine starts to misfire.
These are the codes I recovered. P0606, p2107, p2106, p2196, and p2198. I came on here and Ive been searching for the past few days, trying to gather as much info as I can find. I replaced all the coils and plugs about 3 months ago. Like an idiot, I did not listen to the vets on here and I used cheap ebay coils. Although the car ran fine for that time, those coils probably ruined the PCM.
I know I need to get another PCM and take it to a dealer to have it married. What are my options for getting a second key? I only have one. Also, I will most likely replace the coils and plugs soon after even though the cheap coils "seem" to run fine. I checked the primary and secondary coils on each and they were all above the minimum resistance. I have no way of stress testing them. Should I replace them first just in case its the coils and not the pcm? I ask because Im not sure if bad coils would cause issues BEFORE the engine starts. Would bad coils interfere with the PATS and keep the engine from starting? Thank guys!
