you either didnt read my post or you dont understand the difference btwn the battery reconnect procedure and the drive cycle procedure..
new battery will kill itself if you dont follow the procedures
may its not me who can't read but you who can't write, you clearly said procedure
s which is plural, meaning more than one, so you literally said that the battery
willwhich for the record is not may, but will means absolutely...) kill itself if both of the procedures are not completed, not one procedure or the other...
if you just popped in a battery and did nothing else, you didnt do it right. go read your owners manual. there is a specific procedure for installing a battery and you can drain it if you dont follow it, especially in cold.
NO, it won't drain a good battery by not relearning everything right away, you keep clearly showing that you're not even reading the OP... his battery is not dying an hour or two after the car sits, its fukcing multiple days.
if there is a small parasite drain it can be exacerbated by the stress from not following the directions.
your an idiot, the problem IS a parasitic drain! it doesn't matter if it is exacerbated by anything. until the problem is fixed, it will continue to be a problem. period.
just bc a battery is 'new' doesnt mean its fully charged.
again, when giving advice on problem, listen to the symptoms before you tell him what's wrong. he never said that the car wouldn't start right after installing the new battery. it starts, it runs fine, but heres the part you're missing, "if I leave the car sit for a few days the battery goes completely dead'. this is not the PCM trying to save data.
if you get off the forums and go read your shop manual and the owners manual you will understand that the car does save a ton of parameters after dropping in a new battery. i believe one of the final steps of the battery reconnect procedure is to let the car idle for X # of mins before shutting it off in order to prevent an excessive drain on the battery... it saves the parameters to kam while idling instead. if you dont even follow the procedure it keeps trying to rewrite the parameters... so its just going to continue running big draws on the battery everytime you shut it off until it fully sets the kam...
oh do you mean this part straight from the manual?
"When
the battery is disconnected or a new battery is installed, the engine must
relearn its idle and fuel trim strategy for optimum driveability and
performance."
"4. Allow the engine to idle for at least one minute.
5. Turn the A/C on and allow the engine to idle for at least one minute."
or the only bold warning about WHY you need to follow the procedure
If you do not allow the engine to relearn its idle trim, the idle
quality of your vehicle may be adversely affected until the idle
trim is eventually relearned."
never does it say anything about the reason being so that it can save data to keep from running the battery down while sitting and saving, its for optimum driveability...
so go READ something about this specific car before you go popping off about how youve never ever ever ever drained a new battery...
you can read anything you want to, but its not going to do you any good until you understand what you are reading... good luck
