Battery Draining Issues
2002 Lincoln LS V8 w/ 155,000
So I recently did my Valve cover gasket along with the necessary plugs and coils. I had an issue with it not starting but I found out it was just my fuel cut off switch (the little red button by on the driver side). But now I have an issue with the battery completely draining. I had it hooked up to a computer and they said the voltage was a little low, but he never said the numbers. Either way when I get home and if the car sits for a day the battery will be completely dead. Could this be from something that was hooked up wrong when I did the valve cover gaskets? or could it be something else?
**I am going to take the battery in to get a load test done in about an hour.
sounds like battery. Last time this happened with me the motorcraft battery (2 years ago) was only putting out 250CCA out of the 660 it was supposed to. Battery was replaced under warranty for free. Now 2 years later, SAME thing. Heading in tomorrow to get it replaced again. NOt sure why this is happening so soon
