Battery question
itsnotmydaddys
Saint Louis
i need a new battery, im having to jump my car every start. i called my LM dealer and theyre out till tuesday (99.00), NTB doesnt carry em, Autozone doesnt carry em. ford dealer has 2 for 90.00 (duralast). what should i do, shuold i buy the one from the ford dealer of will another style fit. Please help, i need one today.
I tried all sorts of places when I needed a new battery. I ended up getting one form LM. The LS used a vent design, but a ventless style is out there. The one I got from LM is ventless. Make sure the battery you get, if you get it from another place, can be used in the passenger compartment/trunk.
Not positive, but I think O'reilly auto parts carries it. Not sure about Sears or Advance. If you have a system it may be draining your battery. I would suggest getting a heavy duty battery or even running a second battery.
i just called o reillys and they have a silver star for 59.99 with 72 month warranty, and the lm duralast was 90.00 with a 36 month warranty. has anyone heard of a silver star (do they make my blinker bulbs)
make sure it will connect to your vent tube - since the battery is in the 'passenger' compartment (trunk) you got to vent the gases that form when charging it.
My battery I got from lincoln didn't have the vent. They said they improved the batteries to be ventless, and not emit any gases.
If you just want to get the best battery the check out Optima batteries you can get them at pepboys if you have them near you. Gobs of crancking amps, sealed desgin, (importent since the batt is in the trunk and theres no venttalation hell you could mount it upside down if you wantted) plus they have a great warrenty 6 years first 36 month free replament then 36 month prorated. There about $120. Or if you just want a good cheep battery go to wallmart (evil A$$holes) and get one of the yellow neverstarts never had a problom with them and I think they have a 5 or 7 year warrenty not shure been a while since I got one should be about $70.
This is true I have a red top in the LS and I never had a problem and I beat the hell out of my battery I sit in the car for hours with the radio and tv and all my stuff on and never have a problem worth the little extra for the battery and the peace of mind its gonna start.... I bought this when I had the S-Dime and used it in the truck pulled it out the day i traded it in put it in the ls the second day i had it and never had an issue yet
A+ battery
I bought mine from ford but I think it was a Motorcraft. I guess it does not really help since it is not a duralast but it has been a good battery. The thing with batteries if you get a dud you usually find out before the warranty is out. So just buy one and don't worry about it because if it does go bad it will probably not cost you anything.
Good Luck
:Beer
This is true guys. An Optima is a gel battery...and you actually can mount them any way you want and they work great. Plus, since there's no fumes, etc, there's no corrosion build up on the battery posts!!!
So which battery is better, Yellow or Red?
Would any sealed - Maintenance Free - battery work in the trunk? They do not have vents.
yellow is a deep cell battery I got the red because I was into BBIIGG systems and lots of electrical running so that which one optima recommened for me the red is a little cheaper and all the optima's are warr. for quite some time
as far as the any battery working I would say as long as it is the same specs as the stock battery (or higher) it should be ok (as far as cold start amps and BLAHH BLAHH )
why not spend a little extra and have it outlast anything else cheaper over time I ve had this battery for 2 and 1/2 years NO PROBLEMS EVER
where do you buy these red and yellow top batterys and dose anyone have a pic of them i have never seen them befor
I have had optima's in two of my other cars and swear by them. Heck I wish they made them small enough to fit in my motorcycle.
When I have an issue with the original battery in the LS, I will buy an Optima.
My wife who is cheap when it comes to car parts (especially tires, shocks and batteries) can see the difference in the optima, just by looking at the nine year old one that is still cranking up the 89 mustang coupe that I sold to her best friend.
when i check the optima site for a battery for the ls, the site say that there are none avialble for the ls.
then I went to pep boys today, and they can not find the battery in their system. then i carry my battery in and they say that they don't have an optima battery as large as my battery.
if you have an optima, what size/series do you have?
Another vote for the Optima red top. I've got one in my 99 Camaro SS that previously sat for weeks at a time and it never once gave me a problem. Now, I keep a trickle charge on it and expect it to last forever.
A friend of mine had two yellow tops for at least 10 years. They were both used for the audio in his truck. Never once a problem.
As for one that fits, you probably won't find one. The one in my SS didn't fit quite right either. I had to modify the hold down.
-Pete
02LSE
