What is the best route to run power (the positive and negative wires) from the battery to the engine compartment in a 2000 LS? What gauge wire would you recommend? Going to hook up an electric fan.
There is already a heavy feed running from the battery to under the hood. It goes to the starter and the alternator (where the power for the fan will be coming from anyway). There's a junction in the front right wheel well that would be a good place to tap the fan in (both power and ground are there). In fact, this is where the gen II electric fan power is connected.
