battery
RustyBaker
Long Island
My battery is dying overnight. My rear bags are getting old and the compressor has been going off while the car is off. I figured that would be the problem so i turned the air ride switch off and left it overnight. Drained again. would the compressor sitll go on? what else could it be?
The car will continue to keep level up to an hour after you shut it off. You may want to leave the compressor on all the time as this is normal. Sounds like it is time to replace your bags, this is to be expected.
Either you have an issue with a device being left on over night or your battery is going. There is a post about Alt. Batt. issues that has some good pointers to go over.
