came across a pinout for the wire harness going to it, looks like 12v in the center and switched grounds on the two outside terminals? Is this correct?
If so, im curious to test mine while its still on the car to see if its the dccv or the wiring because i put that new motorcraft yg in it back in 2016 and it didnt fix the nonstop hellacious heat coming out.
years ago i do remember a dtc from the CCM giving a dccv error, i'll have to redo that scan again since its been some years..
I'm back dabbling with the ac, so this is why im revisiting this dccv heat problem... and want this heat fixed because it pushes heat through the vents even in the summer time with the climate controls OFF. I do love it in the winter, but summer and spring fall its nasty..
I just have a hard time believing a new motorcraft dccv came out the box defective, so i'd like to "bench test it" while on the car just to see if it does SOMETHiNG.. I just remember it being a nightmare to put in, hands and arms all scratched up and bleeding from the tight fit. Would be nice to just put a toggle switch on the thing to switch closed for summer, and open for winter! That's an idea i could get behind if i have wire gremlins.
EDIT: have been reading about the CCM having burnt traces from a bad dccv causing a short.. does anyone have pics of this? im proficient with soldering and small smd repairs so i could have a look..
