DUVALINCOLN
Well it's been about 3 months and 3 different mechanics(including the dealership as one) later and still dealing with the same issues, check engine light reading codes of 0133P, 0133, 0153, 0153P. So far I've had the coils, all spark plugs , O2 sensors, water pump, intake manifold and some other things replaced during this project of finding out what is causing the code.
Here is what I know. The car has a rough start-up in the am when I first start it and then its fine the rest of the day except for a few shakes here and there. One the check engine light comes on I get the same codes as listed before. Then i can hear the engine fans coming on as odd times like first thing in the morning when i start the car after it has sit all night. Sooner or later I get the overheating problems and take to shop. Same cycle since the summer and no one has been able to locate the issue. The last mechanic is found coolant in the spark plugs and addressed that problem. About a 3 weeks later same issues engine light, code, fans, overheat. Took in and the water pump had went out. Yesterday check engine light, same codes, now just awaiting the rest of the pattern.
