Good day fellow members,
I'm new to this post and have a question about my 1997 Mark VIII LSC, if someone could be so kind as to help me out. First, I have to tell you that I am far from Mr. Goodwrench! My car just turned 19k miles, when I found that the starter went. I had a mechanic replace the starter and when he did, he found that my upper control arm bushings were almost gone from sitting. I had him replace the parts and when I got the car back, I found that I had no air conditioning. I checked around under the hood for any unplugged connections or vacuum hoses but found none. The mechanic came back over to my house and checked too but found nothing. I placed my hand on the refrigerant tube and it is ice cold however, the air coming out of the vents inside is hot. He told me it is probably a blend door actuator but has no idea how to replace it. Is there member (besides a Lincoln Dealership) in the Berlin, Voorhees, Cherry Hill area that knows about this problem that might be able to take a look at the car and possibly repair it?
Thanks!
Thanks!
