Blend Door Stuck ?!?!?!?!?!
tdymorris
Magnolia
Recently i have been using my heat, well a couple "nice" days came along and i wanted to use the air. I set the temp to 60 and put it on AUTO and it blows out hot ass air full blast, this happens anytime i hit the AUTO button, The temp outside was well above 60 when this happened, and its kind of annoying! Any suggestions?? Oh and when i first got the car in the summer the air worked great, but seems to have stopped now that i have used the heat, i dunno?!?!?!?
No, the blend air door is not stuck, since the LS doesn't have one. It is most likely a faulty DCCV. (Yours is a classic symptom of a failed DCCV.) Unfortunately, this seems to be a common failure. DCCV = Dual Coolant Control Valve, it does the same job that two blend air doors would have done. Do a search, you will find lots of posts about it.
That DCCV is usually the bad part....p/n XW4Z-18495-AA list is $274.80 and LVC is $178.62 plus shipping...plenty of stock on hand.
Max Zuckerberg
Parts Specialist
Five Star Ford
7100 east Mc Dowell Road
Scottsdale AZ 85257
Local 480-949-7617
Direct 1-800-866-1520 ext 236
Fax 1-480-949-8478
parts@fivestarford.com
+2 Dccv
I agree DCCV, not a bad job to fix, just a little tight. I suggest you replace the FORD hose clamps with worm drive clamps, their easier to work with.
This DCCV, is this the part that mounts on the radiator shroud passenger side with 2 coolant hoses that come directly off of it?
Max Zuckerberg
Parts Specialist
Five Star Ford
Scottsdale AZ 85257
Local 480-949-7617
Fax 1-480-949-8478
I did mine this last summer, and got it for under $150..new. Very easy.
ok guys i fix the blend door now my dash wont fit back into place
and i need help cause i work at 445pmand i need help call me at 704-430-5037 that my cell phone HELP ME PLEASE
Naw I think that is 94 Mark 8...94 blu 8 but I am guessing...profile is not complete.
I had the same problem, bro, when last summer hit. I was pretty aggravated cause I had to have the windows rolled down and the moon roof up.
I took my car to Firestone and refilled the "Aintifreeze" i think it was? Or the material that makes the temperature cold. They also put in a Dye that will let me know if it gets a leak.....cost me around 350 for the job. But to survive summer with cold air....well worth it.
