I'm looking to find out the bolt size or part number for the bolt that holds down the air filter box assembly.
I'm changing out all my coolant hoses. I removed the box, pulled out the filter, found a bunch of leaves in the bottom. Flipped the box over to dump out the leaves, and the bolt jumped out and ran away...
I was also amazed at how much debris was packed and clogged in the drivers side window wiper drain! Also, the intake around the cabin air filter was completely packed with debris.
*Edit* '06 3.9
*Edit* '06 3.9
