Just purchased 1995 Mark VIII LSC (143,000).
Drove car home from New Orleans (100 miles).
Few issues.
1. Vibration when accelerating that lasted
a few seconds then quit. Seemed to only
happen at lower speeds.
2. Washer fluid low prompt on dash, washer
reservoir full .
3. Idles rough at stop light
Note: Removed IAC Control valve, noted
gasket was thin and brittle. New IAC on
order
Note: Removed TPS and noted rubber
compression gasket worn out on side .
Note: Changed spark plugs and noted 1
plug had oil on bottom
Any advise , direction, would be greatly
appreciated.
Few issues.
reservoir full .
order
appreciated.
