Brake fluid leaking on the top on the engine by the pass. side firewall??
vikingdiesel
Chicago
I couldnt find the leak anywhere, the brake pedal went to the floor and I topped the brake fluid resevoir with brake fluid and I press the brakes and it squirted from the passanger side by the firewall. Seems like its coming from (2) pipes that are connected to hoses or somthing, not really sure. anyone have a clue or a pic of what im talkin about?
What year?
Brake fluid in the engine bay.
You shouldn't be getting any brake fluid originating from that area.
Get a shop light.
Get an assistant to hit the pedal.
Stick your head in the engine bay and the passenger side wheel well. Don't get in the path of the fluid though. It's sorta under a sh!tload of pressure.
Look again. You'll find it.
